Впускной трубопровод
1 17105RCJA01 GASKET, IN. MANIFOLD
17112RKB003 SEAL, BORE PLATE
17140RKB013 COVER, IN. MANIFOLD (UPPER)
4
17146R70A01 GASKET, IN. MANIFOLD COVER (UPPER)
5
17150RNAA01 ACTUATOR ASSY., BYPASS VALVE
6
17153RCAA01 GASKET, BYPASS VALVE ACTUATOR
17160RYEA10 MANIFOLD, IN.
8
17181RCJA00 PIPE, EGR
9
17213P0GA00 RUBBER, IN. COVER MOUNT
10
92900060140B BOLT, STUD (6X14)
11
92900080503B BOLT, STUD (8X50)
12
957010601808 BOLT, FLANGE (6X18)
13
9405006080 NUT, FLANGE (6MM)
14
9405008080 NUT, FLANGE (8MM)
15
957010603508 BOLT, FLANGE (6X35)
16
957010806508 BOLT, FLANGE (8X65)
17
966000602018 BOLT, SOCKET (6X20)
18
    14.3 KB · Просмотры: 215
