Водяной насос (2)
Водяной насос (2)
1 18011R70A00 VALVE SET, EGR
2 18715PB2000 GASKET, EGR VALVE (ISHINO GASKET)
3 19200R70A11 WATER PUMP (MAGNA POWERTRAIN)
4 19222R70A11 GASKET, WATER PUMP (MAGNA POWERTRAIN)
5 19301P8EA10 THERMOSTAT ASSY. (NIPPON THERMOSTAT)
6 19305PR7A00 RUBBER, THERMOSTAT MOUNTING
7 19311R70A00 COVER, THERMOSTAT
8 19410RYEA10 PASSAGE, WATER
9 19411P8AA03 GASKET, FR. WATER PASSAGE (NIPPON LEAKLESS)
10 19412P8AA02 GASKET, RR. WATER PASSAGE (NIPPON LEAKLESS)
11 19505RN0A00 PIPE, CONNECTING
12 37870RTA005 SENSOR ASSY., WATER TEMPERATURE (DENSO)
13 91307RTA005 O-RING (DENSO)
14 91314PH7003 O-RING (31.2X4.1) (NOK)
15 92900080220B BOLT, STUD (8X22)
16 9405008080 NUT, FLANGE (8MM)
17 957010602208 BOLT, FLANGE (6X22)
18 957010602508 BOLT, FLANGE (6X25)
19 957010803508 BOLT, FLANGE (8X35)
    23.8 KB · Просмотры: 213
