Внешняя панель - Панель крыши
1 04631STX305ZZ PNL R,SIDE SILL(DOT)
04635STX305ZZ PANEL SET R, FR(DOT)
04636STXA80ZZ PANEL SET, R. RR. (OUTER) (DOT)
4
04641STX305ZZ PNL L, SIDE SILL(DOT
5
04645STXA01ZZ PANEL SET, L. FR. (OUTER) (-305ZZ IS THE NEW PLASMA-CUT STYLE.)
6
04646STXA80ZZ PANEL SET, L. RR. (OUTER) (DOT) (-A80ZZ IS PLASMA-CUT)(DO NOT DISGARD CARTON,CHECK FOR ADDITIONAL PARTS & INSTR.)
62100STXA01ZZ PANEL, ROOF (SUNROOF)
8
62130STXA01ZZ RAIL, RR. ROOF
9
63120STXA01ZZ STIFFENER, R. FR. PILLAR
10
63175STXA01 SEPARATOR, FR. PILLAR (LOWER/OUTER)
11
63210STXA00ZZ STIFFENER, R. CENTER PILLAR
12
63217STXA01 SEPARATOR, CENTER PILLAR (OUTER)
13
63220STXA01ZZ REINFORCEMENT, R. SIDE SILL
14
63320STXA10ZZ GUTTER, R. RR. PILLAR
15
63520STXA01ZZ STIFFENER, L. FR. PILLAR
16
63610STXA00ZZ STIFFENER, L. CENTER PILLAR
17
63620STXA01ZZ REINFORCEMENT, L. SIDE SILL
18
63720STXA00ZZ GUTTER, L. RR. PILLAR
19
64135STXA01 SEPARATOR, FR. PILLAR (LOWER) (INNER)
20
74470SAA003 GASKET, FUEL LID LOCK
21
74480STXA04 ADAPTER ASSY., FUEL FILLER
22
74481STXA02ZZ LID, FUEL FILLER
23
74490STXA01 GROMMET, FUEL LID
24
74700STXA01 ACTUATOR ASSY., FUEL LID
25
74701STXA00 ROD, ACTUATOR
26
74852SDAA21 SNAP
27
74853SDAA21 WASHER
29
85280S3VA00 PROTECTION, SIDE PANEL (OUTER)
30
90222SB4000 NUT-WASHER (6MM)
31
934040601207 BOLT-WASHER (6X12)
90178STX003 BOLT-WASHER (6X16) (L. SIDE)
33
63236STXA01 SEPARATOR, R. CENTER PILLAR (LOWER)
34
63509STXA00 REINFORCEMENT, SIDE SILL GARNISH
35
63636STXA01 SEPARATOR, L. CENTER PILLAR (LOWER)
36
74175STXA00 GROMMET, SIDE SILL REINFORCEMENT
37
75450SAA013 OUTLET ASSY., RR. AIR
38
90126SS0000 BOLT-WASHER (6X16)
39
90316S6M003 NUT, POP
40
74482STXA01 SPRING, ADAPTER
    17.6 KB · Просмотры: 244
