Блок управления (Двигателя) (2)
1 32146SH3003 CONNECTOR, DIODE (2P)
2 37820RYEA75 CONTROL MODULE, ENGINE (REWRITABLE)
2 37820RYEA76 CONTROL MODULE, ENGINE (REWRITABLE)
3 37821RYEA10 BRACKET, ENGINE CONTROL MODULE
4 37822RYEA00 BRACKET C, ENGINE CONTROL MODULE
5 37823RYEA01 COVER, ENGINE CONTROL MODULE
6 38100STXA02 HORN ASSY. (LOW)
7 38150STXA03 HORN ASSY. (HIGH)
8 38211SNAA11 FUSE, BLOCK (30A)
9 38211SNAA21 FUSE, BLOCK (40A)
10 38221SNAA31 FUSE, BLADE (7.5A)
11 38221SNAA41 FUSE, BLADE (10A)
12 38221SNAA51 FUSE, BLADE (15A)
13 38221SNAA61 FUSE, BLADE (20A)
14 38221SNAA81 FUSE, BLADE (30A)
15 38231SFY003 FUSE A, MULTI BLOCK (120A/70A)
16 38231STXA01 FUSE C, MULTI BLOCK (40A/30A)
17 38232STXA01 FUSE D, MULTI BLOCK (60A/50A/40A/30A)
18 38235SNAA01 PULLER, MINI FUSE
19 38243STXA00 BRACKET, MAIN FUSE BOX
20 38246STXA01 COVER, MAIN FUSE BOX (UPPER)
21 38247STXA01 COVER (LOWER)
22 38250STXA01 BOX ASSY., RELAY
23 38255SNA003 DETECTOR UNIT, ELECTRONIC LOAD
24 38256STXA02 COVER, RELAY BOX (UPPER)
25 90114STXA00 BOLT (6X21)
26 90129S84000 SCREW-WASHER (5X14)
27 90150S84003 BOLT, GROUND (8X16) (L. SIDE)
28 934040601204 BOLT-WASHER (6X12)
29 934050601608 BOLT-WASHER (6X16)
30 934050602008 BOLT-WASHER (6X20)
31 957010603508 BOLT, FLANGE (6X35)
32 9820040750 FUSE, MINI (7.5A)
33 9820041000 FUSE, MINI (10A)
34 9820041500 FUSE, MINI (15A)
35 9820042000 FUSE, MINI (20A)
36 9820043000 FUSE, MINI (30A)
41 934050602008 BOLT-WASHER (6X20)
    54.1 KB · Просмотры: 210
