Бензобак
1 17044STXA00 TANK SET, FUEL
2 17045STXA00 MODULE SET, FUEL PUMP
3 17046STXA00 NUT & GASKET SET, FUEL LOCK
4 17047STXA00 METER SET
5 17048STXA00 Фильтр топливный
6 17052STXA00 REGULATOR SET, PRESSURE
7 17519STXA00 PROTECTOR, FUEL TANK
8 17521STXA00 BAND, R. FUEL TANK MOUNTING
9 17522STXA00 BAND, L. FUEL TANK MOUNTING
10 17525S3VA00 BOLT-WASHER (12X35)
11 17576STXA00 GUARD, FUEL TANK
12 17651STXA01 TUBE, FILLER NECK
13 17652SDAA31 CLIP, FILLER TUBE
14 17652SDA003 CLIP, FILLER TUBE (28.6MM)
15 17653STXA01 TUBE, VENT RETURN
16 17655STXA01 PIPE, VENT RETURN
17 17656STXA01 CLIP ASSY., VENT RETURN
18 17660STXA01 PIPE, FUEL FILLER
19 17670SNAA02 CAP, FUEL FILLER
20 17711SDCL01 RETAINER (NATURAL) (TOKAI)
22 17711S0X003 Кронштейн
23 74660SDAA00 CAP ASSY., FLOOR MAINTENANCE HOLE
24 90150S04003 BOLT, GROUND (6X16)
25 90361S3VA00 NUT, CAP (6MM)
26 91593S9VA01 CLIP, FUEL TUBE
27 91594SNAA01 CLIP, FILLER CAP
28 91595STXA01 CLIP, FUEL PIPE
29 91601SH3013 GROMMET, SCREW (5MM) (BLACK)
30 934030601608 BOLT-WASHER (6X16)
31 934070802004 BOLT-WASHER (8X20)
32 9390125220 SCREW, TAPPING (5X12)
